paradog
Will a 2004 Viper drive axle fit/work in a 1997 Mountain Max?
it will fit but you will lose your speedo drive as the viper uses a reluctor wheel on the end and yours uses a gearbox with square drive tang.
Out west in the MTNS should only be concerned about a working tack lol
I saw guys with only a huge VDO on the dash
grapeape
Do you need a drive axle? I have a spare sitting here.
Yamaha_Ryder
Yes it will fit, but as Viper said you will lose your speedo. The viper axle is a solid axle and much stronger than the 97.
