Alaskanparret
I was going to go riding today but, After turning my machine off with the kill switch, the kill switch broke and will not come out again(even after sticking a pin in there). I took apart the kill switch to where there are 2 brown wires and one black and one black and yellow wire.
Can I just clip the wires and get a new switch? Will it start if I clip the wires? Is there somewhere I can just unplug the kill switch?
Thanks for all your guys help!!!
super1c
Super Moderator
Just follow the wires down the handlebars you should be able to just unplug them and be fine if i remember right? Then just repalce the switch, or just find a new throttle block complete from one of the guys in the classifieds.
Alaskanparret
I follow the wires down undo the first connection that leaves the unit about 6 inches long follow those wires down and unplug the black and yellow wire and the black and white wire at their clearish green connection and still a no go.
schwanysrx700
take your handle bar pad off, follow the wires from the skill switch to the first connector and un plug it, you should be-able to still start it and shut it off with your key.
Alaskanparret
Well after undoing the first connecting... Nothing.
Could it be that it isn't completing it's circuit? Or that I disassembled the kill switch prior to disconnecting it?
staggs65
you dont want it to complete the circuit. when you push in the killswitch it completes the circuit to ground and kills the engine, you want the circuit open
