I need to jet my brother in laws 98 sx vmax 600. What size mains do I need for 6000ft. Or where should I look in the tech. Im having no luck
Anyone know where to find an online manual? or at least a sheet for high elevation jetting for 98 sx vmax 600
Was that a triple?
At 8000+ I ran 137.5 or 140 depending on the temps. Dropped the needles some too, but don't remember off hand what the setting was. Clutching was 8Cr's with 3.6 in each hole. Was a touch heavy on the tip so I lightened them a bit, but would probably be fine at 6000'.
No not a tripleYZViper366 said:Was that a triple?
Mysledblows said:At 8000+ I ran 137.5 or 140 depending on the temps. Dropped the needles some too, but don't remember off hand what the setting was. Clutching was 8Cr's with 3.6 in each hole. Was a touch heavy on the tip so I lightened them a bit, but would probably be fine at 6000'.
Thank you
