GoBlue
- May 30, 2005
I spent a lot of time searching for this topic, but never found directions for doing it. Can someone direct me to a link for this job. We have the secondary off and upper and lower gears w/chain. Thanks
super1c
Super Moderator
Are you trying to remove the speedo side drive bearing or chaincase side?
polarisconvert
Jackshaft, not driveshaft
That is what I get for posting late. I meant the jack shaft bearing behind the secondary.
Sorry
Sorry
super1c
Super Moderator
What sled? I know on my vipers if i remember right you just have to undo the bracket that holds the bearing in place and remove the 2 setscrews in the bearing collar. Dont lose, hard to replace. some new ones dont come with the set screws.. Then it should just slide off if not rusted on to bad. Might want to hit it with some PB blaster to help ya out some. Here is a pic of the bearing collar.
super1c said:What sled? I know on my vipers if i remember right you just have to undo the bracket that holds the bearing in place and remove the 2 setscrews in the bearing collar. Dont lose, hard to replace. some new ones dont come with the set screws.. Then it should just slide off if not rusted on to bad. Might want to hit it with some PB blaster to help ya out some. Here is a pic of the bearing collar.
Super1c. That looks like a nice clean organized motor. Congrats.
Millinocket Rocket
I was just coming on here to look up the same thing....good info. Glad we don't have to pull the whole shaft out or get into the chaincase. Bearing part# I found was 93399-99943-00 at YamahaSportsPlaza.com.
