Belt deflection?
coryv4
Michigan
how do you adjust the belt deflection my belt sits just a hair below the secondary its a newer belt harldy any wear. also what should peak rpm be on the 98 sx600 twin its about 8200-8300 right now.
Your belt deflection is spot on ..no need to adjust, your rpm shift out should be around 7800 rpm! you adjust be adding or removing 3 lil washers on the back side of the sec.( 3 bolts)
when i have it idling on a track stand my track is hard to spin by hand i heard you should be able to touch it an it will start spinning
