'07 Phazer Mouse nest
bgddy3465
Albany, NY
We finally got a couple inches of snow. So I fired up the Phazer, waited for it to idle down, no problem. As soon as I squeezed the throttle I knew I had a problem. No power. So I squeezed harder, then she died. A mouse nest in the muffler! My own fault. I was able to remove the insulation with a copper wire thru the tail pipe. But now she won't fire. An ideas?
Fouled plugs. It doesn't take much to foul a Phazer 4 stroke if they don't get a chance to warm up.
Time to take the seat off and work your way forward to the plugs. Tiny little buggers. The socket should be in the tool kit.
opsled
Yeah. I tried it again today. Same results. Probably gunna have to take the seat off and yank the muffler. Try it again & see what happens. Thanks guys.
