Can someone tell me if the two clamps in this picture are in the correct place and if so what lines do each one of them hold. Items A + B in the picture.
Also, on item C. is this a problem. I had been contemplating replacing the oil seal behind the impeller but realized there's a mechanical seal also. I decided not to replace it. Then I dug up this old picture I took during disassembly to try and figure out the clamps and noticed that it looks like oil is coming out of that weep hole. Is that an issue I should be concerned with?
rlbock
weep hole is from waterpump/oilpump shaft seal area, you will see a little weeping oil there. Clamp B holds the oil line coming to the oil pump. Not sure about A. Not sure about location of both either.
usually only have clamp B, but would not hurt to run the oil line thru A also and up to pump. someone must have been in there before or someone at factory not paying attention.
The hole is the weep hole and you will see that stain on there from the oil, as long as antifreeze doesnt drip out theres no problem.
BrainDead13
they are in the right place, just so you know
