what should be a good starting point setting on a new rear shock? currently nut is ran all the way up.
your manual will show you the specs you can adjust to.
i dont have a manual. is their one on this forum?
yami1
Go to yamaha website. You can view manuals on there
or become a VIP on here and get the manual from here.
Spring preload (SX600)
1. Adjust:
• Spring preload
Adjustment steps:
• Turn the spring seat in or out.
FRONT SHOCK
Min.-----Standard---- Max.
203 mm /213 mm /213 mm
(7.99 in) (8.39 in) (8.39 in)
REAR SHOCK
Min.-------Standard-------- Max.
358.5 mm /368.5 mm /378.5 mm
(14.11 in) (14.51 in) (14.90)
1. Adjust:
• Spring preload
Adjustment steps:
FRONT SHOCK
REAR SHOCK
where is that measured to? ground to the grab bar in the back?
can't get a pic..but them measurements would be the distance to top of spring to the bottom of the spring against the adjuster nut.
here are some spring charts to look at..maybe this may help ya also...
http://www.totallyamaha.com/snowmobiles/aaTECH/Suspension/specs/suspensionspecs.htm
