Flashing Check Engine/warning lamp
srxman06
shakopee,mn
I have a 02 Viper that I rebuilt the top end this year with new wiseco pistons and rings. My question is, i just got back from a weekend in the U.P and we put 250 miles on it. It runs fine but when I get on gthe throttle and it hits about 6500-7000 RPMs the orange warning light and check engine light flash about 5 times and then go out. not sure the exact number of flashes...Any idea's??????
Do you have a stand? I used a 8ft step ladder and a ratchet strap once. If you can hit that rpm on stand it should trigger that light sequence. Then you could have it fixed if and when you get snow
I will try to get it up on a stand and run it. Using 91-92 octane. I have not maxed it out yet. A bit nervous still. Just did a rebuild on it this fall,so i'm still breaking it in
