KyleArgall
hey guys, i just swapped out my stock track with a 1 3/8 sno cross track today. and i must say the hook up is insane but there is one problem, IT DOESN'T TURN!! my carbides are still good so i was thinking i had to adjust the weight transfer? any input will be greatly appreciated.
thanks.
thanks.
livewire_101proof
Look at bethevipers suspension setup in the tech section. Has detailed info on suspension setup and characteristics of adjustments, should tell everything u need.
X2 on betheviper's set up tips I followed them word for word sled launches straight and turns on a dime
Back off the pre load in the skid's front shock and pull up the limiter straps to get more weight on the skis.
KyleArgall
thanks guys i thought it had something to do with the limiter straps.
Also increase spring pressure on front springs........all sorts of combos........
Weight transfer is key! Check out BTV's sig and you will be set. It is a lot of reading and some work but well worth it. IMHO the weight transfer is key... Read it all and you will be set.
KyleArgall
yeah ive been doing a lot of reading here on the forums. it sounds like as soon as i get it all dialed in it will be a whole new machine. i will be playing with the weight transfer later this evening.
pitz0022
IMO adjusting the skid is the difference between loving and hating a Viper. I just got back from a trip. For the first day and a half I fought the sled and got beat up because I didn't have a chance to dial it in around home. At lunch on the last day I made one adjustment (moved the FRA from medium to Soft) and while not perfectly tuned, it was a joy to ride the last half of the last day, even on the rough trails. Now I need to go back through the procedures again and readjust everything. I believe it will ride and handle very well then.
