Okay measured offset and secondary needs to go in 4mm but it's against the bearing? How do you adjust that?
staggs65
you need to loosen the engine mounts and move the engine
Devilin AblueDress!
X2 should be able to slide motor out 4mm no prob
as you do that you have to be aware of center to center not going out of whack also.Have to have some patience on this...took me a while to line everything up.
