brianbailey440
can anyone tell me why every other light works exept the headlight, its driving me nuts!!!please and thank you.
newyamaha2me
check harness under engine for start... after obvious bulb and wire plugs
bulb is burnt out
brianbailey440
i checked everything known to mankind, and its still just the headlight that doesnt work,any other suggestions?
brianbailey440
im not getting power to the high low and low beam switch either
Pull the pad cover and pad in between the handlebars and check the wiring there. I had a flickering headlight problem/no power to the brake light switch and found 3 broken wires there. They were by the cowling in the middle of where the handlebars mount to the steering shaft. I had to peel back a bunch of the tape and bam there they were. They were rubbing on the steering shaft. I Fixed them by cutting about 4" out of the wires, used some new wire, soldered them together and used heatshrink tubing and electrical tape, re-routed them and voila.
brianbailey440
ill check
brianbailey440
got light?
found them, thanks i appreciate the info!!!
Racing666 said:Pull the pad cover and pad in between the handlebars and check the wiring there. I had a flickering headlight problem/no power to the brake light switch and found 3 broken wires there. They were by the cowling in the middle of where the handlebars mount to the steering shaft. I had to peel back a bunch of the tape and bam there they were. They were rubbing on the steering shaft. I Fixed them by cutting about 4" out of the wires, used some new wire, soldered them together and used heatshrink tubing and electrical tape, re-routed them and voila.
EXCELLANT POST!!! I have not run into that one yet, but I will remember your discovery, nice job!
motorhead327
Sticky, Sticky, Sticky!!!
brianbailey440 said:found them, thanks i appreciate the info!!!
Were they broken where I suggested?
mrviper700 said:EXCELLANT POST!!! I have not run into that one yet, but I will remember your discovery, nice job!![]()
Thanks! I actually found them when I pulled the harness under the engine out, and it was flawless. Then I started tracing wires and found the broken ones under the handlebar pad / cowling.
motorhead327 said:Sticky, Sticky, Sticky!!!
Definitely a good idea!
