devfurnace
This may sound like a dumb question, but I don't know the answer and that's why I am asking. The float inside the gas tank, is it supposed to float freely or only when you start the snowmobile. I would go out and start it up but I have the oil switch out testing that so I can't start it up at the moment.
devfurnace said:This may sound like a dumb question, but I don't know the answer and that's why I am asking. The float inside the gas tank, is it supposed to float freely or only when you start the snowmobile. I would go out and start it up but I have the oil switch out testing that so I can't start it up at the moment.
Doesn't matter if the sled is running... the float will float regardless.
devfurnace
Well I just went out to see if I could figure anything out about the float. When I looked in the tank earlier I could see the float at the bottom of the tank, had a long screw driver that has a bend end kind of like a hook and I had tried pulling up on it, but it didn't want to budge. Didn't really want to pull on it too hard because I thought maybe it was something in the sending unit that would make it not float. Now that I think about it, that didn't make sense. snomofo had said that it will float regardless (thanks for the reply by the way) which made sense to me. So I went out with my long screw driver and pulled up a little harder and sure enough, popped right up and is floating freely. I'm pretty sure it's fixed now. I have no idea what it was stuck on though. Oh well as long as it's fixed I guess I'm not too concerned.
maybe the fuel line with filter dropped on it and was holding it back..
devfurnace
Well I guess that didn't fix it. Must have broke something when I pulled up on it. Was going to take the unit out but I have too much gas! First time I have had too much gas for anything. Guess that shows how much riding I have done. Wanted to ask, when taking the whole fuel level sending unit out, do I have to take the whole tank off? Or do I have to take the steering shaft out because it is right behine it and I don't think you can get it by. Any info would be great.
You have to move the steering shaft out of the way.
gil7247
I've got A sending unit sitting on the shelf I'm not using. Shoot me a pm if it'll help you out. I'd let it go cheap. Gil
Racing666 said:You have to move the steering shaft out of the way.
I'm guessing it'd be easier to remove the tank rather than the steering post.
9801srx
x2 minutes to remove tank vs hours to remove steering shaft.snomofo said:I'm guessing it'd be easier to remove the tank rather than the steering post.
devfurnace
Actually it wasn't that bad to remove the steering shaft. All you have to do is get it out of the way a little bit so i un bolted the top bracket and just moved it out enough to pull the sending unit out. I have a quick question. Is the rod that the float on supposed to be curved?
devfurnace
Well I just looked it up on a parts diagram and it looks like it is supposed to be straight. Must have bent it when I pulled up on it because it was caught on something in the bottom of the tank.
gil7247
The one I have is straight
devfurnace
I think I fixed mine. I am going to be putting it in, in a little bit and will let you guys know what I did with it. Pretty simple fix.
gil7247
Let me know if it works. I can send you the one I have in the morning if you need it. Just pm your address.
devfurnace
Just put it back in, fired it up and works like a charm. was a really easy fix. Will post pictures later to show everyone what I did.
