i took my srx 600 out last weekend and it would stall if the choke wasnt on so i took the carbs off and cleaned them and now it only runs in 2 cylinders under 6000 rpm and if its ran for about 10 minutes the headlight will shut off and the motor dies it will start right back up but i just dont know why its dieing any ideas?
check for wire rub through and your plug caps..
another fella on here just had a similar issue with only 2 cyl's firing.He changed plug cap and all is fine now.
Thanks will that stop it from dieing after riding for a while too?
if it is dying,then another issue.Your pilot jets may be plugged.
