1995vmaxfun
I need some advice i bought this sled in october and rode it once in december and it ran ok i did notice alot of black oil around the exhaust ports very wet. I rode it for the second time today (finally got some snow) ran good for about 5 min then developed a very bad bog at wide open. I put the choke on half when it would do this it didn't help still lots of oil aroud exhaust. From what i can see is that it has a thinned head gasket and a gyt single pipe i jetted it for 1000 feet hear in nebraska.
caravanman
I had a fine wire electrode spark plug that failed that did what you are talking about. It had about a .060" gap after the electrode fell/wore out. Ran fine until I was past about 3/4 throttle then just bogged, worth a quick look.
Oil around the flanges to the head is very common, the factory seals never worked very long for me I was able to get replacement ones in the past that were a gasket material not the metal sealing ring style and they worked much better they look like a small block Chevy thermostat gasket.
1995vmaxfun
I chacked the plugs they look ok, wet but ok good brown color. I am going to put ne ones in. Removed carbs and disassembled them they look clean. The carbs have 152.5 main and 52.5 pilot, needles at 2. what is the float measurement? I removed the pulse hose for fuel pump looks dry. any ideas. should it have br8 or br9 plugs the sticker says 9 when i got it it had 8s.
1995vmaxfun
is it possible to take the fuel pump apart and clean it or is it not wise
1995vmaxfun
After cleaning the carbs and some new plugs I took it out for a test ride it ran great rode for about half hour I don't really know what fixed it. Supposed to get some snow tonight I will try it again tomarrow
