makoren
I am having no luck finding these helix angles. Does anyone know where I could find a list for these. The numbers on the helixes are 8bv86, 8bv30, and hauk H.
the 30 would be 43*, never seen an 86, number doesnt jive with oem style. could be re-cut and re-stamped or you misread the number. others should chime in on the hauck. there was a hauck list posted on here some time back.
staggs65
there's the aftermarket helix thread in the tech faq section. didn't see the hauck h though. I'd like to know too I've got one of those hangin around. I could measure it I suppose next time im in the shop but would like to know the claimed angles
9801srx
found this old post by turk (rip) he said straight 43 so ya can take that to the bank. http://www.totallyamaha.net/forums/showthread.php?t=42199
makoren
Thanks for the reply guys. From what you are all telling me the 8bv30 is a 43* and the 8bv86 is also a 43*. They are for sure not identical angles when matcing them up though. Now I am really confussed.
makoren
Well I found a post from Mopar1rules way back in January of last year which said"hauck H which is suppose to be 47/43, measures 45/41". So that one is a multi angled helix. Which one should be a better one to use for the stock setup for my 97 600sx then? I have read in Turks area that the best one is a 51/43 but then gear up one tooth. Which gear should it be or is it both?
