Oil pump cable question
KEVIN
VIP Lifetime Member
OTTAWA
When adjusting the oil pump cable are you just measuring the exposed cable you can see when you pull them apart?
correct. pull cable sheath off the joint till it doesnt pull anymore. then use a dial caliper to measure the cable lenght
smaller gap=more bigger=less havta run it and see what your sled is getting to get exact ratios. manufacturer spec is usually safe. not sure what setting is on the srx.. but i like to run a lil richer on my viper especially since it is aftermarket piped. and vipers came lean from the factory.
Wow no wonder my sled drinks oil
The gap is 13mm and spec is 20-22
after adjustment just make sure to keep tabs. on your actual consumption ratio. rich is better then lean. cranks are expensive.
I will adjust it on the richer side and keep an eye on it
