spowersrr
Hello, just installed a 1.25" ripsaw track on my 02 viper and noticed the lugs are hitting 2 aluminum square tubes tack welded in front of heat exchanger thats just forword of the drive shaft. Im wondering if these are just protectors that can be removed or if its a structural part of the exchanger. Maybe i should switch to an 8 tooth driver, but with all the research i did i thought this track would work with my stock drivers. I will not be studding this track so that wont be an issue. Thanks for the help. I found this site last year and love it!
