Kehien to a mikuni on 340 exciter?
rich
LeRoy MI
Hello, i took a 38mm kehien off a 77 340 exciter. I replaced it with a 38mm mikuni. The jetting i have in it now is main 380 pilot 40 a 2.5 slide needle 6DH3 with the clip in the 4th from the top and the needle jet is a Q-0. Any thoughts on this if i should be close? Had it started and run on the stand and the air screw liked to be at 3/4 turn out. Also no air box. Running a filter. Thanks Rich.
Update; 400 main 6DH4 needle in the 3rd clip position seems to be very close now according to plug color.
