76 Srx Carb ? Re Power Jet Nossle
techman
I have a 76 SRX 440 Mikuni power jet carb that the white plastic nossle for the power jet broke off. It is the white plastic 90 degree elbow that is mounted on the intake side, see pic below. The plasitc is broken off but there are still brass parts inside that don't want to come out.
Any ideas?
THAT SHOULD BE JUST PRESSED IN. MIGHT BE ABLE TO FIND ANOTHER. I DON,T RECALL ANYTHING BRASS BEHIND IT. I BELIEVE IT WAS A PASSAGE WAY. (hard to remember) 3:16 (yammie tony)
Grab On To It With A Pliers And Twist It Will Come Right Out Find Another Power Jet Carb And Switdh The Nozzle Over To The 76 Carb
