rodny51082
i read on an old post that the stock setting for the oil pump on a viper was 20mm. my viper is piped, and in the same post they said that 19mm was recomended.i installed new extended rsi cables and have set to its longest possible length. i measured at the adjusting joint and i only get 16.38mm is this set to rich or will it be ok since it is piped?
