APEXMAN
hello all a simple little ? i have a 99 sx 700 and iam wondering about the secondary clutch hanging up i noticed the buttons are numbered do the numbers have to match the holes or what i dunnno.....
98srx6
You add the 2 numbers that you put your secondary spring into and multiply by 10 to get the degrees of twist in your secondary....if that made any sense at all.
APEXMAN
yess i no that but the buttons are actually numbered 1,2,3 on the ends of them .....98srx6 said:You add the 2 numbers that you put your secondary spring into and multiply by 10 to get the degrees of twist in your secondary....if that made any sense at all.
yamaholic22
put them in the same holes as the 1,2,3 on the secondary
98srx6
Is there a reason for doing this?
