Fox Shocks on my old Phazer
mrmaxman
California
Hey Guys, I picked up an old 88 Phazer for a parts sleds and when I pulled the rear skid out low and behold there was a set of Fox Shocks installed. Just wondering if Yamaha had these as an option or if somebody down the road installed them. I rebuilt my skid for my 86 Phazer, installed the Fox, and must say the ride quality is a huge improvement.
I will sell you a set of those shocks . I took them out of my 1989 phazer when I put a new skid in it . Reicharts performance sold them and front fox shocks back in the day . PM me .
what are the measurements on those?carefull with that rear one in a 89,90,its longer and as i found out you need to make some adj, to keep the bottom shock mount from flippin down and smasing the shock body into the middle idler wheels,its actually the same length as a 88 sus,i have the setup directions for em if you want,also they do work much better,
88 ex f=10 r=14
89 ex f=10 r=13
just what mine are,might work in an exciter,rpc directions say to run rear arm in front hole,strap in 3
what are the measurements on those FOX shocks?
carefull with that rear one in a 89,90,its longer and as I found out you need to make some adj,
i have the setup directions for em if you want, also they do work much better.
88 ex f=10 r=14
89 ex f=10 r=13
just what mine are.
RPC directions say to run rear arm in front hole, strap in 3
dsc577
I'm a total newbie on the Phazer-I/II sleds..
I have found a pair of Ohlins shocks from an 1989 Phazer-I skid and was wondering if they will fit on a 1991 Phazer-II skid ?
Hi Phazerdeelux
I sent you a PM since I see you're in New England
KR
ok. do you find a other goods quality ohlins or fox for phazer II? i have find # of model ohlins YA 9203 Yamaha Phazer II,
Center ('90-'93) in old post, but i didnt find shock.
Ohlins part # for Phazer-II
* TSS front suspension: YA9502
* Skid Front: YA9202
* Skid Rear: YA9232
