Is 20/38 gearing ok in a Venom?
Mikedom
Caledonia, WI
I have a '06 Venom that I was looking at putting reverse on. The bottom gear in the reverse kit is a 38 tooth, and I currently have the stock 20/39 gears in it. I have done Turk's clutch setup years ago to get rid of the overrev. This sled is perfect after the rivet changes in the clutch, and I don't want to affect this to much. Would putting a 38 tooth bottom gear change things too much for this 600 red head? The current ratio is 1.95, changing it would make it 1.90. Any thoughts??? Mike
