Powervalve adjustment questions
snopax
Wisconsin
This may be a little anal retentive but when adjusting my servos per the sled tech article, one side of the housing always closes over the 2.5m wrench first. Would this be the stopping point or do I continue to tighten until the other side of the housing meets the wrench as well. If I was to continue it always feels pretty snug on the side that closed first.
I found that a coat hanger bent into a u shape works well also. Yes you want both sides to touch with just slight drag. Remember the specs are 2-3.5. Your good to go!!
you can leave the 2 bolts in and simply lay the allen wrench across them, adjust the cable till it touches the 2.5mm wrench laying sideways across bolts and your done.
