thetorches
What Is The Proper Torque For The Head Bolts On A 2002 Viper. Thanks.
killerklown
I assume you mean the "nuts".
Tighten in two stages. 9.4 ft-lb. then 20 ft-lb.
thetorches
The bolts that attach the head to the cylinders.killerklown said:I assume you mean the "nuts".
24 on the base nuts and 20 on the head bolts.
SeX Viper
Does anyone have the proper sequence, I have read it is on here some where but I can't find it.
here ya go you should be able to click on the image to resize it..SeX Viper said:Does anyone have the proper sequence, I have read it is on here some where but I can't find it.
