Blown up 700sx... What years of cylinders will fit?
700 triple
ON
Hi everyone, I blew my pto side a couple weeks ago going down the lake. My mechanic said I will probably need a cylinder too. What cylinders will fit? Will only a 97 700 sx work, or will other models / years work?
Thanks!
It is my understanding that, they are all the same. I have just ordered one from one of the companies that does the renickasil, and they take yours in exchange. Better identify why the PTO side went, bad seal??? plugged jet, before replacing or you do a repeat. Unfortunately you'll have to get an new head gasket, $$$ since it's a single
we are going to figure out why it blew before I get parts, Il give the guy a call tonight to see if hes took a look at it. the piston wash was a white/grey. Looked like some aluminum grit on the plug. other 2 cylinders were burning perfect.
So all the red head 700 cylinders will work?
