Skid help?
sledwrecker
Mn.
I'm in the process of changing my short travel skid into a longtravel. I've installed longer front shock and limiter straps, along with long transfer rods. Installing skid is impossible. The rear idler shaft won't come even close to mounting holes in tunnel. Do I need to relocate? What am I doing wrong? Someone please help!
Did you try to loosen the transfer rod bolts. Loosen them all the way it should help ya bring them in line easier. I even take them out bolt in the skid then put the transfer rod bolts in. No relocation is needed.
loosen up the transfer rods just to where they are almost all the way out and loosen the back wheels where the shaft goes through the wheels, then loosen the two bolts that are located on the back of the skid that moves the back wheels forward and back.
Thanks guys! I'll give it a try. Not that it matters. Haven't had enough snow to ride all season.
