davidgboy
i have not taken out needles on these type carbs before. wanted to raise needles as mrviper700 suggests. rather use a little more gas than melt pistons. fairly easy? any tricks? i looked in manual did not see much.
remove the top cover ..unscrew the 2 little allen key ..hold the trotthle fully open and remove needle with a magnet .....select the way u want the needle position
you can also take the slide holders right out. it opens up room and makes everything that much easier. be carful of the shims.. they are very small and easy to drop and have them dissapear into oblivion.
davidgboy
thanx i will give it a try. think i will go up to next richest level. i think i will try to avoid constant mid range use if possiblemodsrx said:remove the top cover ..unscrew the 2 little allen key ..hold the trotthle fully open and remove needle with a magnet .....select the way u want the needle position
davidgboy said:thanx i will give it a try. think i will go up to next richest level. i think i will try to avoid constant mid range use if possible
almost impossible ...your are 3/4 of time there..carefull not to lose the little plastic shim ....
davidgboy
thanx for the warning will have to familiarize myself with this procedureandrew k said:you can also take the slide holders right out. it opens up room and makes everything that much easier. be carful of the shims.. they are very small and easy to drop and have them dissapear into oblivion.
davidgboy
modsrx said:almost impossible ...your are 3/4 of time there..carefull not to lose the little plastic shim ....
i was afraid someone would say that. better take this precaution it would seem
davidgboy said:thanx for the warning will have to familiarize myself with this procedure
its easy take your time ...your gonna be good on the third carb lolll..just unscrew those allen don't remove them from the carb ...they are small ..
davidgboy
modsrx said:its easy take your time ...your gonna be good on the third carb lolll..just unscrew those allen don't remove them from the carb ...they are small ..
will be even better when i get to my brothers viper. i kind of talked him into getting the vipe instead of keeping 2001 sx700r. have to admit we have already ? the decision. need to do all we can to keep from being regretful
exactlydavidgboy said:will be even better when i get to my brothers viper. i kind of talked him into getting the vipe instead of keeping 2001 sx700r. have to admit we have already ? the decision. need to do all we can to keep from being regretful
davidgboy
andrew k said:exactlythats what ive been doing too. its so much easier to figure out the quirks ask questions and fix them before hand. then pay the piper... so many people have been there done that bought the t-shirt... so all we have to do is learn from past mistakes and be that much better off without all the expensive (i didnt realize that could happen) repairs in the future. yamaha preservation lol.
yup- i still feel bad about being an a$$wipe at times on here. was a good place to vent.my viper was pissing me off with that idle hang. i am afraid i alienated mrviper700. dont blame him actually. first impression wasnt good. past is gone now though. at least i offered an apology to all. what else can u do?
davidgboy
oh nor the second, third..........impress. lol
A long tweezer can help with getting the slide lifter out after the allan screws are unscrewed. You just push the slide lifer sideways off the shaft then with the tweezers maneuver it around so it comes out.
I have adjusted the needles with the carbs on the sled but for the first time I would suggest you do this with the carb rack removed from the sled and sitting on the work bench. Its also a good time to clean the carbs...don't forget the "top hat" fuel screens under float needle seats.
JM.02c
Bob
JM.02c
Bob
davidgboy
sideshowBob said:I have adjusted the needles with the carbs on the sled but for the first time I would suggest you do this with the carb rack removed from the sled and sitting on the work bench. Its also a good time to clean the carbs...don't forget the "top hat" fuel screens under float needle seats.
JM.02c
Bob
yup, might try them on sled first. certainly try and be careful. i have had those carbs off more times than i care to recall. yes i did the top hat screens when i had them apart. they were perfect actually. thanx
JM.02c
Bob
X2 The first time I did them it was on a bench. You'll save your back and not be rushed.
