4strokesmoke
Well it seems like my srx likes oil. The sled uses a tank of oil per 1 1/2 of gas ! I just think this is a bit too much. What is the proper adjustment for the oil pump?
s10mike
i think its 18- 21 mm.
newyamaha2me
u should check your cable for the right gap.. if i remember right you should have 20-22 mm space on your cable..
guys posted the right specs for you. You dont by chance have a bar riser on it do ya? these sometimes will pull the adj. cable and make the sled use more oil if the cable adjustment was correct.
