BurlyViper
I was bogging at WOT on my stock 02 Viper. Found a broken powervalve cable. Should I just replace the one cable and adjust the other 2? Or should I replace all three? Is this a common problem? After I repair this, I assume I should do a compression test to make sure I didn't cause any other damage. Any other suggestions? Thanks.
I would check the other two and only replace as required. But I am no expert.
just inspect the cable make sure there is no fraying at the ball end ..the cables do strech a little but as long as you got enough cable to adjust them no need to replace them ...i have cables if you need one ...also i would look to make sure the ball end has not started enbedding it self into the valve itself ...most of the time the ball has started making a hole in the valve top which actually makes it impossable to adjust the valves correctly ...so if you need a cable or valves repaired just contact me .........
BurlyViper
Sent PM. Thanks.
