Gitterdun1985
bender quads on 95 800 primary www spring 8bu's loaded, secondary stock spring with 49/42 helix at 100 degree. on a good day it will only rev 85 do i need to take weight out oif inner.
If your looking to raise your shift out rpm you can either take some weight out of the tip of the fly weight or back off the secondary wrap 10* and see what that does.There is a sort of rule of thumb as to how much rpm per gram of weight is required but I forget it right now.I think it's something like 1 gram to 250rpm?
