tractordanp
so had this 99 srx 700 for a few years had a hauck clutch kit pulled very strong but only to about 8100 rpms was not real sure this was best set up so
last year switched to heel clicker set up vforce 3 reeds with spacers cold air kit and transfer rods all from bender plus dyno port stingers went through power valves not to bad but some build up sycronized pulls real hard i mean streachs the arms good but still only to 8100 what am i missing?
oh 23 38 gears
oh 23 38 gears
justin1620
What clutching components are you using weights, helix, springs,etc.........have you tried wrapping your secondary more to see if your over shifting? Are power valves clean?
orchie18
im not experienced with heel clickers but sounds like your trying to pull to much weight in you primary clutch
tractordanp
pv are clean and adjusted complete heel clicker set up from bender big red primary spring bender helix and yellow secondary spring at c 6justin1620 said:What clutching components are you using weights, helix, springs,etc.........have you tried wrapping your secondary more to see if your over shifting? Are power valves clean?
not sure what is the yellow secondary ..but for sure u got to mutch tip weight or middle all depend your set up
YAMMIEGOD3:16
C-6 ? You Have Correct Secondary On This Sled. 3:16 (yammie Tony)
tractordanp
ok just found my set up sheet from bender says heel clicker weights 4.8 on heel 5.5 center 1 on tip with red heel clicker spring 9870c helix yelow spring at 80 degrees 8200 - 8300 shift rpm
your sled should be around 8350 so your close anyway.
tedgoesfast
ive always clutch them to start at 8200 and pull to 8500 at end this seems to work good
98-99 shoot for 8250rpm, try just a little less weight
