Got 1980 Srx motor putting 1976 cylinders on.the 80 cylinders have the injection intake flanges should I use these on the 76 cylinders I know the ports are larger but would I benifit from using these as they would be used as a spacer or should I mount the boots right to the cylinders and scrap the spacer.I'm not using the oil injection.
YAMMIEGOD3:16
DON,T RUN THOSE. THAT SPACER WAS FOR BUTTERFLY CARBS. 3:16 (yammie tony)
Ok that answers that thanks alot getting ready to put it all together still waiting on a set of heads.
dynofun
- Nov 14, 2005
I still have those heads but one other guy asked for them before you and i have to check with him. Sorry for the delay.
Ok well let me know if he don't want them thanks.dynofun said:I still have those heads but one other guy asked for them before you and i have to check with him. Sorry for the delay.
