SXViperGuy
Will a 4in pivot riser fit on an 01 SXViper without modifying anything on my sled?
super1c
Super Moderator
Nope, 3.5 is the most and thats with the controls moved in a tad and bars forward. 3 is safe and easy
snoprokidf6
if you get flat style bars, you can safely slip on a 6 in, my brother squeeked on a 7 in
SXViperGuy
I don't wanna modify anything so im gonna go with the 3in thanks guys
akrievins
2" fit no problem on my 03 Viper without moving a single thing. 3" should be okay as well.
akrievins said:2" fit no problem on my 03 Viper without moving a single thing. 3" should be okay as well.
How tall are you? Is 3" enough?
SXViperGuy said:I don't wanna modify anything so im gonna go with the 3in thanks guys
I think you will need to reroute the brake hose with a three inch rise
akrievins
I'm 6' 1". I could have used a bit more, but even the 2" helped.
pivot riser and 1.5 riser fit mine. believe thats 3.5. dont quote me though
Agpetro
I have a 4in raiser on my 03 viper. Had to get 03 mtn viper cables and longer brake cable. I'm 5'11" and thinking about putting a 6in raiser on.
