vmax4 800 clutching
Gitterdun1985
Lincoln, New Brunswick
vmax4 800 with quad benders, 8bu loaded ,www spring,2 shims,secondary stock spring at 9-1 100 degree 49-42 helix. I can only get it to rev 8500. im almost certain that it has a short cover on primary will this affect my rpm. :2strokes:
DUDE, YOU USE MY CLUTCH SET-UP IN YOUR 800, WHY NOT DROP ME A PM SO I CAN HELP YA. LAST WEEK YOU HAD A BAD BOG, THAN YOU WERE BLOWING BELTS, THAN YOU BLEW YOUR CHAINCASE APART. I,LL DO THIS FOR YA . THE REASONS WHY YOU DON,T GET TO TARGET RPM.
1. JETTING
2. CDI OR STATOR WEAK
3. POSSIBLEY BAD REED
4. SPRING BIND (clutching)
5. CLUTCHES ARE GETTING TOO HOT.
GOOD LUCK 3:16 (YAMMIE TONY)
