hymark roller
yamahasrxman
flushing michigan
Has anyone used or heard of a hymark roller secondary I have a bender clutch kit on my srx was wondering if this hymark roller would be worth buying and if it would be a good upgrade any info would be great
I've heard of them. I don't think many people used them tho. Also, hard to find helixs for them and helix choice is limited. I would look into other roller secondaries, like hauck magnum shift.
Thanks I couldn't find much info on them and what I did wasn't good does a roller secondary make much difference or would I notice much compared to my bender clutch kit
I never cared much for the bender clutch kits. They aren't very good IMO. I think you would be better of using one of Turk's clutch setups found in the Tech pages, or a tried and trued 8BU setup that can be found while searching, versus buying a roller secondary and bolting it on.
Yeah i bought it for quick bolt on but I took the clutches to a guy to install parts ive never takin them apart them things are like a grenade if not put together properly do you know of a good setup and what would need to be changed weights and springs and helix the bender kit made a difference but I'm sure it could be better
what type of riding do you do? what engine mods are done to your sled? what springs and what angle helix is in your bender kit? what is the letters engraved on the inside of the helix, near the bottom of one of the ramps?
Mostly trail riding and some off trail only engine mod is bender can kit came with yellow springs not sure of angle I looked last nite but not on the inside of helix ill have to go look
