SRX transfer rods for travel
Bushc
Michigan
SRX transfer rods for long travel
I have a 2001 SRX with adjustable transfer rods can I use these with Viper shocks or do I have to use different rods. If I can what mounting point holes should I use front or rear.
With longer rods such as a viper has they use the rear hole, the shorter rods like srx has mounts in the forward hole. Most srx has the thick shim on the bottom though, u would want to put the thin spacer in there for the right gap for long travel.
if i recall on the SRX stock transfer rods with the viper shocks you need a 10mm(i believe that's the thickness, it's the thinner one) spacer on top and underneath. all i did was use my thinner spacer as guide and ground the thicker one down to match. ;)!
