viper heads
lhviper
PA
I have mega power heads on a viper. When riding normal it seems fine, but if you do a long wide open run you can smell antifreeze and I noticed on the front of two of the heads its a little bit wet and you can see dried antifreeze .Do I have a major problem or can I still run it til end of season and fix it then? Thanks for the help .
If it were me, I would already have the heads off to find out whats going on. If there's antifreeze leaking out, there's air coming in. Yank the heads before you burn the motor up. Might be a cheap easy fix rather than a really expensive one.
