mountainx01
i just cleaned my carbs and was wondering if i should put a in line fuel filter in somewhere just because there is fuel from last winter still in the tank i put startron in it but it still clogged my pilot jets.or will i be ok to fuel up with fresh gas.
SWEDE
I'd start with all fresh gas. Siphon the old all the way out.
Yes you should find a dealer that can sell you a Racor water removing inline filter!
http://www.parker.com/portal/site/P...toid=f5c9b5bbec622110VgnVCM10000032a71dacRCRD
We sell them where I work, not trying to hijack and sell you. Contact me if you'd like. An extra filter certainly can't hurt and to be able to remove water even better!
Have you replaced the stock fuel filter yet? Drain the gas, replace the filter, be sure carbs are clean and you should be good.
mountainx01
i never realized there was a fuel filter already on it is it visible?
It's inside the tank on the pickup line. Also screens inside the carbs.
