WIsnoRyder
Agpetro
WIsnoRyder said:What you think is the cause of this??
Thats what my piston looked like when i burned one up two years ago. What caused that was running a head that was modded by bender racing and after the fact finding out that it was cut wrong.
That almost looks like my burn-down last year. I had a leaking exhaust manifold port. It turns out my exhaust manifold was warped and although two were tight up against the port the other one couldn't get tight because of the warped manifold. All unknown to me being the happy new to me but used owner. I lost a chunk out of the piston kind of like yours. My piston skirt was cracked also. Bummer! I feel for you, and know the pain.
what year SRX and what was your jetting at the time and temps..and were the carbs clean inside.
tedgoesfast
went lean lean is not good does some bad things
lean burn down, even the pic of the good piston is on the lean side, barely any wash, so you have too lean of jetting somewhere in the fuel curve,needle setting,main jet, etc.
detonation prob ran lean
A couple of bucks
Seeings how it's lean & detonating across the board, what octane fuel was in it and how old was it?
WIsnoRyder
it had 91 octane ethenol free fresh from the pump from kwik trip. It is a 2001 srx with 1600 miles on it.
check the jetting then..When I pu premium gas,I put the hose in my truck and pump about a gallon thru the hose because the customer before me was using regular..then I fill my container up.On the trail you will have to dump 1 gallon on to the snow first then fill up..lol
