clutch parts id?
Caneadea, NY
just got a spare set of clutches, was told off an 01 srx. anyways has some weights that look like polaris weights, not holes for tuning, 10-54 on the side of it and it does use the smaller bolt with a collar to use them. had a yellow primary spring with a blue stripe. secondary had a what apears to b an oem pink spring. guessing this was some sort of bender kit, anyone know anything about it. wondering what kind of aplications that weight would be used for. maybe something i can play with sometime, or maybe useless to me. thanks
polaris weight.
In the grass days, I saw a PRO-X 600 driver with a coat hanger full of different fixed weights he said it was easy to swap them out for conditions then tune the existing fly weights.
I heard they can run good on the trail. They have a lot of meat down low to grab the belt hard and fairly fat at the tips for top end squeeze. They actually look to have more meat then the 8DN-20s with a steady profile through out the entire shift
You would have to have a proper set up for a secondary but people run cat and poo weights
