t.o.r.s. fixed?
davidgboy
winthrop maine
hooked my t.o.r.s. backup. the carb. switch seems to be the achilles heel with this system. u can peel back the rubber boot on bottom of switch and spray some wd40 or similar in there. seems like it might help keep it from sticking. i did not realize that oil pump return spring has enuf force to reliably return throttle lever if throttle assembly becomes jammed. should have been more diligent. seems to be working o.k. right now. i will still keep kill switch in mind.
