Track question
Bad98SRX
Omaha
Stupid question jus wanna make sure i get it right....... How Do u tighten the track on a 98 srx and how do u tell jus how tight its suppose to be and wut bolts do u turn to tighten it?
loosen axle nut. turn 1 or both of the adjuster nuts that face 2 the rear. have 2 access thru track. loosen til u can turn it by hand. shoot for even gap between each edge of track and tunnel. run it a little. make sure it wont rachet. adjust accordingly
To elaborate on "threw track" at the very back of the sled look threw the windows (square holes in middle of track) theres a stud with nuts on it. If track is centered in tunnel already you shoul move nuts equal turns.
Once the tension is close, spin the track (with the engine) and let it come to a stop on it's own. Since you'll be adjusting the tension nuts through the track windows it's a good idea to shut the engine off. Then check the gap between the outer shoulder of a track clip near the rear wheels and hyfax.
If the right side has a larger gap, tighten the right side tension nut about 1/4-1/2 turn then spin the track and recheck the gaps. Once the left side and right side gaps are even tighten the axle (often forgotten), recheck the gaps and you're done.
sweet thanks guys yea this is quite a bit different then my ol thundercat jus wanna make sure
