First post
srx steve
Buxton, Maine
Hi guys my name is steve . I have a 98 srx 600 when i got it it was in boxes.So i've been working on it for 3 years . I have been a member for about a year and i have learned alot reading all the diffrent posts. This is an awsome site. So im finally ready to ride. after going through every nut and bolt .new track doo skid , long travel front,rebuilt top end, fixed power valves. now my question is i tested the power valve servo on the bench with a battery it seemed to work fine installed it on the sled brought RPMs down to 900 still seems to be working fine so i set valves to spec . my problem is the sled runs great pulls hard all way to 80 mph and still is pulling but i get the 7 flash code for the servo . what could the problem be ? A glitch in the cdi or a bad servo not working at wot.
my rookie mistake was when i backed off adjusters i adjusted to spec without pulling on the cable housing .. i learned just because you back the adjusters off it doesnt give you a proper reading if you can slide your cable still without pulling on pv.. make sure you didnt adjust without pulling cable slack up.. i was beginning to think the 7 flashes was letting me know i was going fast...
You will always be going to fast. Enjoy all your hard work. Take it slow until you get everything sorted.
SRX Steve,
So is your doo skid and track a 16" track? How'd that fit...any problems?
Belated 1 year welcome also!
Newbee its a 121x15 hacksaw with a sc 10 III skid install was not that hard doner sled helps but theres lots of info on this site. there is tons of info on here you just need to look for it thats why i havent posted because everthing you need is here. thanks so much for the welcome.
thanks staggs65 i've learned a lot from you and mr viper,betherviper,and so many others just about every question you need ask has all ready been answered if you spend a little time looking just do a search . you guys are awsome!!
there is a tool you can build that will allow you to setup the PVs without having to run the engine.
It plugs into the lead for the servo and uses a battery to provide power to it.
You would adjust the cables until the PVs dont wiggle anymore.
I tried to find a post that give instructions on how to build the tool but I am unable.
Maybe someone can help with instructions.
3 years of rebuilding a sled and now no snow to ride on :o| I thought I was depressed lol
tell me about it . i have a little snow i can at least test on the lake . i was thinking about going up to millinocket this weekend does any no how the riding is
:letitsnow thanks staggs65 nice video wanted to go to jackman couldn't find a room all booked up.holiday weekend found a room in millinocket leaving friday morning hope everything goes well should be fun.anywhere in norhtern maine is beautiful
staggs65 said:
lol yeah but if you could see my backyard I was more interested in the snow
I hear you there ! going north this weekend hopefully theres some snow the people i booked my room from said there was a 12-24 inch base on the trails we will see hope its worth a 4+ hour ride. :letitsnow
