vector
I am replacing the clutch on my vmax 600 currently the sled had a comet clutch on it and I am replacing it with a clutch from a 99 vmax 500. The 600 is a 98 XTC. Will the setup work in the 500 clutch or do I need to change anything. Your help is appreciated.
vector said:I am replacing the clutch on my vmax 600 currently the sled had a comet clutch on it and I am replacing it with a clutch from a 99 vmax 500. The 600 is a 98 XTC. Will the setup work in the 500 clutch or do I need to change anything. Your help is appreciated.
Clutch will go right on but you will need to make changes to the spring and fly weights.
Vector, there "should" be info in the tech section as to what spring, weights, and rivets(if not mistken) that came in your sled from tje factory. That is, if you want to put it back together completely stock, if you wish to change the clutching from the stock configuration to gain some efficiency over stock this is also located in the tech section.
