83 Enticer 300 top rebuild
yamajake
North of GR
ordered 2 new piston kits (piston, rings, wristpin, clips). SPI was the only ones available for the 300. Problem is, the top slot on both pistons, the rings do not fit no matter which way (or ones) i try to install. Anyone ever run into something like that? (the pistons and rings all came in the same box as a kit)
The bottom slot fits the rings just fine.
I was going to order a couple .040 over sets of those but got told they may not be too good. Interesting...
I'm stupid....i finally mic'd the rings. they are different sizes and beveled to the inside. they are not marked well, but fit perfect once the rings where in the correct slots! (rings were diff thicknesses by .020mm)
