yammyhamer408
hey guys in a pinch here went for a ride today and my 01 srx died on the side of the trail no worning nothing sled has no spark i have tested stator and wiering harness and cant find anything. and i have a ride to go on tomorrow cant find anything wrong sled has bran new cdi on it as well
Devilin AblueDress!
I remeber reading about one of the relays for the hi or low beams causing problems like this. I dont remember the exactdetails but the guy pulled on sled till his arms nearly fell off. Hit the hi lo switch and it fired right up. Long shot but worth a try
Devilin AblueDress!
http://www.totallyamaha.net/forums/showthread.php?t=80579&highlight=losing+spark
Read post #6. this isnt the thread I was remembering but same issue
yammyhamer408
that did not work it has no spark at all and will not start it is driving me up the wall
Sounds more like a wiring harness problem if the stator and cdi are fine. Did you check the entire harness for a rub thru?
yammyhamer408
ill check the harnes i just went through the hole harness 600 km ago
yammyhamer408
i have came to the end of my rope im changing the hole electrical system harness and all realys my cdi is brand new and so is my stator and voltage regulator.
Devilin AblueDress!
Bad ign or kill switch? Shoul be able to just unplug either to test......I think?
ottawaair
Last year we had same issue on an 01 also. Found a rub thru on the harness running down the bar on the way to the CDI.
Does the headlight light up at all when you're pulling it over?
yammyhamer408
the light will not light up with a digital igniton srx
yammyhamer408
looks like i sold the sled i got an offer today for 1500 and im done with the sled its going to a great home the guy buying it is like my second dad so i can use the sled when i want
Devilin AblueDress!
I would say did good getting 1500 out of a non running sled. Just curios...Wheres espanola?
davidgboy
yammyhamer408 said:looks like i sold the sled i got an offer today for 1500 and im done with the sled its going to a great home the guy buying it is like my second dad so i can use the sled when i want
sorry u had to go thru that much grief. when u get to ride it be respectful. they demand that. will be tempting to thrash it hard.
bluewho
Just west of sudbury and north of manatulin island ...thats in ontario.Devilin AblueDress! said:I would say did good getting 1500 out of a non running sled. Just curios...Wheres espanola?
travgag
I'm having the same thing, no spark, well very dimm and sometimes no spark, great snow storm we had eh ! I'm from val caron and wanted to go riding before the warm weather and rain, but guess not.
cheers
cheers
