MY01SRX
Can you put viper cylinders on an srx. Will it give you performance gains?
they will bolt on, but thats about it! Nothing else will work exh system wise, they are completely differnt exh port bolt patterns and lengths. plus the srx uses o-rings for the heads and the viper doesnt have o-ring groves for the heads as it uses a headgasket/flat surface.
there is better porting specs on a viper vs a srx
MY01SRX
Thank you for the information.
