jasonlmrx
Does anybody know all the differences with the normal viper 700 and the viper 700 mountain? Im loking to do a hole conversion on mine and im looking for clutch specs and chaincase gears n links on chain and suspension and track size all the important stuff anyways..
Thanks very appriciated.
Here you will find the a page of factory specs.
http://www.totallyamaha.com/snowmobiles/AAATuning Chart/Specs.htm
in addition to the specs, the skids are different as are the mounting locations. you will need the mtn drop brackets, bumper,  as well as the extension and hose covers and the rear exchanger is highly reccomended.
if your going to run a 2" track, you will need 8t drivers. if you care about the speedo, you will also need the mtn one thats corrected for the smaller drivers.
beyond what you already can find on stock clutching and gearing, most the stuff is the same although the mtn viper as the hood intakes configured differently to reduce snow ingestion along with the all important deflector for the exhaust outlet.
i am sure more will come to mind, that should give you some things to digest.
